Radiator Fan
gra
Radiator Fan
Post by gra »
Hi all,
Can anyone please give me instructions of how I can get at the radiator fan on my 2002 1.1 206.
Thanks in advance,
Gra
Re: Radiator Fan
Buy Haynes Manual 4613.
gra
Re: Radiator Fan
Post by gra »
Thanks, I wonder why I never thought of that!!!
Re: Radiator Fan
Did you get your axle fixed?
gra
Re: Radiator Fan
Post by gra »
Yes thanks I did get my axle fixed but not not by bying a replacement axle, a guy re-bushed it.
Re: Radiator Fan
Good, well done.
As for your 1.1 radiator, most of us here on the CC forum have 1.6 or 2.0 litre engines so will not be familiar with the layout of your 1.1 engine compartment. You can obtain a brand new Haynes manual for about £16 off eBay - seller: motoringbooksofbookham. Excellent service and cheaper than most other places.
gra
Re: Radiator Fan
Post by gra »
Thanks I didn't realise that, I will endevour to remove my user particulars from the web site.
gra
Re: Radiator Fan
Why not stay with us. You might get a 206cc one day. And we'll try to help with any issues you may have with your hatchback in the meantime.
In general terms to remove your cooling fan you need to
1. Remove the front bumper.
2. Slacken & remove the 3 bolts & washers securing the cooling fan to the front panel. Recover the collar from the rear of each mounting rubber.
3.Free the fan assembly from the front panel to gain access to the wiring connector. Lift the retaining clip then disconnect the wiring connector and manoeuvre the fan assembly out of position.
If you need to remove your radiator as well:
In general terms to remove your radiator you need to
1. Disconnect the battery -ve lead (always advisable)
2. Unscrew the expansion tank filler cap. Drain the cooling system by loosening the drain plug or disconnecting the lower hose from the radiator.
3. Disconnect the wiring connector from the cooling fan switch fitted to the top of the radiator.
4. Release the retaining clips and disconnect the expansion tank hose, and the upper and lower coolant hoses from the radiator.
5. Slacken & remove the retaining screws securing the radiator upper mounting brackets to the front panel. Unclip both brackets from the panel and remove them from the radiator.
6. Carefully lift the radiator out of position, taking care not to damage the radiator fins. Recover the radiator lower mounting rubbers as you'll need them for reassembly.
Good luck.
craigdmjv
Re: Radiator Fan
Post by craigdmjv »
Join 206info they have members willing to help with all models of 206
gra
Re: Radiator Fan
Post by gra »
Thanks for the gen on getting at the radiator very much appreciated, being a senior citizen the 1.1cc is plenty big enough for me.
Gra
Re: Radiator Fan
Senior citizen? Join the club !
