Is there any other way of resetting the service interval, apart from a visit to the local dealer?
Thanks in advance.
Resetting the service interval
- cheekee
Re: Resetting the service interval
1) put key in ignition and ensure steering lock is off.
2) press tripometer button on dash and hold in while switching on ignition.
3) you will see in the mileometer display that it will count down from 10 to 0. once this is done, switch off ignition.
4) when you turn on igniton, the spanner indicator will has gone and its done.
Hope that helps.
Hope that helps.
per reap
Post subject: service counter
[ Post details ]
yes.
press and hold the left and button on the instrument panel
switch the ignition on,and youll have a 10 second count down.
turn ignition off and release the button.
hey presto....all done
Post Posted: 05 Jun 2011 02:41 pm
(Posted elsewhere and copied here)
[ Post details ]
yes.
- Thar
Is there an echo in here...
- cheekee
Yes I wondered that...
yes I wondered that.....
tenderfoot
That was just what the doctor prescribed.
Worked a treat, at least after I had found the correct knob. Being a LHD car, the right side knob was the one I needed to push!
pokemon151
I've just tried it and it worked. Once I found out my trip switch was on the right of console.
What is the one on the left for?
- craigdmjv
i do this as my uncle services mine and they charge 15 pound to reset that down here
