I have jus brought my Lil baby (03, 1.6, moonstone allure) and I love it, jus need to know what air pressure is needed for my tyres, I have looked thru then handbook and can't see =[[[!
So if anyone can help, it will be muchly appreciated
Take a look on the drivers side door surround bodywork (underneath door catch).
There should be a sticker there with the required pressures depending if the car is loaded or not.
On my 206cc, Unloaded the sticker says the pressure should be 2.3 bar (loaded 3.0 bar). It doesnt say what it is in PSI. An online converter says 2.3 bar=33.35 PSI.
Our 2005 1.6 Allure is still on its original Continental tyres and we've always run it with 35 psi front and back when unloaded. The tyres have worn evenly except that at 17,800 miles the front tyres were showing wear at the edges of the tread, so I swapped the fronts and backs (leaving them on the same sides of the car) to even out that wear.
The car has now done nearly 25,000 miles with plenty of wear still left in the tyres.
When running fully loaded I increase the pressure in the rear tyres to 40 psi but this is only very rarely at holiday time carrying full suitcases and with more than 2 up in the car.
Tyre Pressure Measurement Converter
BAR PSI BAR PSI BAR PSI BAR PSI BAR PSI
1.30 bar 17 psi 1.90 bar 27 psi 2.60 bar 37 psi 3.25 bar 47 psi 3.95 bar 57 psi
1.35 bar 18 psi 1.95 bar 28 psi 2.65 bar 38 psi 3.30 bar 48 psi 4.00 bar 58 psi
1.40 bar 19 psi 2.00 bar 29 psi 2.70 bar 39 psi 3.40 bar 49 psi 4.10 bar 59 psi
1.45 bar 20 psi 2.10 bar 30 psi 2.75 bar 40 psi 3.50 bar 50 psi 4.15 bar 60 psi
1.50 bar 21 psi 2.15 bar 31 psi 2.80 bar 41 psi 3.55 bar 51 psi 4.50 bar 65 psi
1.55 bar 22 psi 2.20 bar 32 psi 2.90 bar 42 psi 3.60 bar 52 psi 4.80 bar 70 psi
1.60 bar 23 psi 2.25 bar 33 psi 3.00 bar 43 psi 3.70 bar 53 psi 5.20 bar 75 psi
1.70 bar 24 psi 2.30 bar 34 psi 3.05 bar 44 psi 3.75 bar 54 psi 5.50 bar 80 psi
1.75 bar 25 psi 2.40 bar 35 psi 3.10 bar 45 psi 3.80 bar 55 psi 5.85 bar 85 psi
1.80 bar 26 psi 2.50 bar 36 psi 3.20 bar 46 psi 3.90 bar 56 psi 6.20 bar 90 psi
