HI ALL, A 206 OWNER WITH A STARTING PROPLEM
princess
can any one help,,car turns over ok but will not start,mostimes start fines and runs ok,and then for no reason just wont start,it may take 2 tries or several tries or wait 20 min and then fires up as if nothing is wrong,the car is a 206 14cc 2001 :
Re: HI ALL, A 206 OWNER WITH A STARTING PROPLEM
I'd guess at the immobiliser ring around the ignition barrel. Quite a common fault.
princess
hi
thankyou for your reply,im told it is a easy job,but will i need to programe the key.
many thanks
many thanks
