Fans not working and temerature rising.
braders
Post by braders »
Right then the fans arent working on the 206cc. Im going to investigate this more tomorrow. What i do know after a quick look is that there is a green wire going into 1 of the fan relys and it has come out.
When i say wire its more like a green chalk inside the flex almost like corrosion. Is this a temperature wire?? Will this stop the fans from working??
reap
Re: Fans not working and temerature rising.
Post by reap »
braders wrote:Right then the fans arent working on the 206cc. Im going to investigate this more tomorrow. What i do know after a quick look is that there is a green wire going into 1 of the fan relys and it has come out.
heya. tis common as.prob a supply wire to relay to operate cooling fans :0
