more roof woes
penel
more roof woes
Post by penel »
hi again all
ive been stalking the forum since registering but not logging on too often anyway
here we go again with a roof problem
it all started when the roof went down ok but the boot lid wouldnt lock into position so we lifted it in manual mode and reset everything
roof worked fine retracted it and went for a drive and about a mile down the road the dreaded ping ping ping started
put the roof up manually, reset again and roof retracted fine went for a drive and you guessed it ping ping ping
put roof up manually again retracted roof and now the boot lid wont close hydraulically
so now im starting to get a little frustrated
any pointers would be good as the next step may be the big hammer :D
thanks in advance
ps check the fluid level and it is just in the marks as required
by the way can you get the zhm fluid from gsf
penel
Re: more roof woes
Post by penel »
should have said when the boot fails to close the pump is still working whilst we hold the roof switch in position
any ideas chaps and chapes,s :D
penel
Re: more roof woes
Post by penel »
ok a little update
roof will retract into boot but the small plastic shelf isnt going into place so i pressume that is why the boot lid wont shut
i tried pulling the plastic shelf into position so as to drop the boot lid but that didnt work
imm really getting frustrated with this now so any help would be great
t i a penel
penel
Re: more roof woes
Post by penel »
update number two
major problems now
all we get is a constant pinging when using the roof lower switch and theres no bong when we undo the roof catches
can some one please give us a pointer as im about to be taken away in a straight jacket
ta penel
zacka
Re: more roof woes
Post by zacka »
check out this video on youtube. at 5:46 do you have the small plastic thing?
Thar
Re: more roof woes
Post by Thar »
Don't think I've seen that before zacka...worthy of a sticky I think :thumbs:
Image...............
penel
Re: more roof woes
Post by penel »
thanks for the reply
only got back on the forum tonight
did eventually get the roof sorted it was the micro switch on the left side of the boot hidden behind the boot hinge
now all working honky dory :hyper:
Re: more roof woes
How did you manage to diagnose that?
penel
Re: more roof woes
Post by penel »
i now have a contact that is pug trained and does a few jobs on the side
he even did the cam belt and water pump for me at a price i wouldnt even do it for :D
