Hi Guys I've had the 206cc for 4 years never had any problems with it'
Went I pull the parcel blind over & open the the roof catches' the windows go down as normal the boot lid starts to open when it gets fully open' the roof won't go back? I've found a micro switch under the covering in the boot' once I have fully opened the boot lid I have to used masking tape to hold the micro switch in then press the roof switch again!! Now the roof will go back.
Same when I won't to close the roof press the roof switch to open the boot lid' then tape the micro switch to close the roof'
I have recently had the car resprayed so I might have do something in the boot as I prepped the car before the respray??
I'm not getting any more bleeps then normal'
I'll try to upload a vid. If no one has had the problem I've looked on the forums to see if anyone has the same issues'
Boot lid lifts up' But roof won't go back
tonyken
Re: Boot lid lifts up' But roof won't go back
Hi yougoagogo, got the same problem that you had here, could you explain to me what switch you replaced and where it is to fix it.
Cheers, Tony
Cheers, Tony
tonyken
Hi yougoagogo, still can't find the location of the microswitch I need to replace, is there any chance you could describe exactly where it is, removed all the trim in front of pump and folding shelf.
Cheers, Tony
Cheers, Tony
