Basically i own a Peugeot 206 1.1 (04), 40k miles. Having the following issues:
*Car cuts out occasionally whilst driving, everything just goes dead
*Engine management light is constantly on
*Recently, the sidelights on the right hand side of car stopped working (front and back), i checked all the fuses and they were fine, then last night, the lights all of a sudden started to work, not knowing when i turned the car off and taken keys out of ignition, the front right side light, the rear right sidelight and the number plate lights remain on constantly. I now have to disconnect the battery to stop it draining as the lights are constantly on....im thinking BSI unit needs replacing in stalk?
*The center console heater lights stopped working, but again it started working suddenly last night and now remain on constantly
*Happens rarely, but does occur, turn car off, and radio keeps on bleeping (whilst being on) for about 20minutes then goes
I am guessing ECU problem? if so/not is this going to be expensive to fix? as if we are talking thousands im not sure what to do
Any information/help would be appreicated. thankyou
