Roof Not Working
darreno
Post by darreno »
Hi I have just joined to try and fix the wifes car, any help would be great.
When lowering the roof on my wifes 2001 206CC it stopped working, I manually put the roof back up but now the roof will not operate, the windows lower and when I press the switch I hear the pump but the roof does not move and the pump stops after 10secs and bleeps at me, any ideas?
Why did it stop working? Did you switch the ignition off at the time? Did you undo a seatbelt or something while the roof was operating?
If you search there are posts on here detailing how to do a reset, check reap's posts if you struggle to find it.
Alternatively your Peugeot 206cc dealer should be able to help.
darreno
Post by darreno »
I was holding the button and it just sopped, have attempted re-setting but still no go.
Probably a microswitch then, but there are several of them. I'm no expert on the roof. I'd have to take it to a main dealer to sort out.
