COIL PACK
Which engine?
Basically you remove the engine cover if it has one, disconnect the wiring plug from the l/h of the ignition coil unit, remove any breather pipes that may be in the way, undo the 2 (or3 depending on engine) mounting bolts. Lift the coil pack straight up (easy to damage). You may need to make up a special tool as it can be tight.
