Correct way to reconnect battery
- Thar
My battery needs charging as my car has been off the road and reading the manual I notice it is advised that you reconnect the negative terminal first. I understood that you should disconnect the negative then positive and when reconnecting the positive then negative...why do Peugeot advise the opposite?
