Can not unlock boot - and our x-max gifts are inside
Troels
Post by Troels »
Hi everyone,
We have a 206cc from 2001 - and rarely any problems. However - now we have one - our x-max gid´ft for the kids are in the boot - and it will not open. Key turned left - all noises are "as usual" - but it will not open. I suspect that some item (plastic bag) has got stuck in the catch within the boot - thus blocking the opening. The workshop in here in Denmark tried - no avail. They suggested to cut a hole in the trunk !!!!!
I would like to try out the following: If the Safety curtain in the booth was closed I could open the roof - which would open the trunk cover. I have to "simulate" that the safety curtain is open by x-wiring the switches.
Does anyone know where to find this signal? A simple short between the Out and In should do the trick.
Any help will be very much appreciated,
Regards from Troels in Denmark.
Troels
Post by Troels »
It will be x-mas after all....
Thank you very much for your reply. On the 2001-version there is a small hole behind the left hand passenger seat - only covered by a bit of boot-lining.
After 15 minuts I could open the boot by partly opening the roof. And I got the x-mas presents out.
Thank you very much for helping me out - and a merry x-mas to you ald all the 206cc people here
Well done. Glad to be of help Troels.
A Merry Christmas to you and your family. Hope the children appreciate their gifts.
