Hi just bought 206cc from a local dealer. It has a 3 month warranty thinking of taking it to garage for a check. Anything i should be aware off?. Only fault is roof will not open no beeps, read forum all checks done. Any clues.
Mark
Just bought 206 warranty work?
- Thar
These warranties tend not to be worth the paper they are written on. I usually find when reading the small print that whatever problem I have is not covered for whatever reason, so good luck!
Did you not test the roof prior to purchase or has it stopped working since you bought it?
