206cc airbag and abs faults
mr-c
Post by mr-c »
hi folks, ive just bought a 52 206cc 2.0. 30 k miles
it had a vibrating brake pedal, so i got the garage to fit a new front abs sensor, £60?? which sorted the problem, but while driveing home the abs light poped on, so i returned to garage, the removed the fault( diagnostic came up unknown fault) so drove home and bang it came on again? brakes work perfect though? and also airbag light came on, again diagnostic came up airbags out of sequence???? unable to erase memory, when trying to re set that.
now she has started to miss on startup in the morning, and sometimes when hot too? or standing in traffic, ahhhhh and also a clunk when turning left from the front suspention area,
anyoneany ideas on the faults above? or will i have to put into peugeot? who charge a fortune,
thanks :thumbs:
My suggestions:
Misfire when cold? Hydraulic tappets.
Clunk from front suspension? Broken spring.
Plenty of posts on this forum regarding hydraulic tappets. Do a search.
When was oil and filter last changed? What oil?, and was it a genuine Peugeot filter?
Welcome to the forum.
mr-c
Post by mr-c »
hi thanks,
oil was changed last week with a peugeot filter and shell helix oil, looked at the springs and they seem to be ok?
Misfire: Spark plugs, coil pack, hydraulic tappets?
Clunk: if not spring (they can break right at the ends), something loose under bonnet? Suspension drop link?
