boot rattle
rockdene
Post by rockdene »
Just bought my car (which looks just great) but have a boot rattle on the left hand side when on bumpy roads (which are all over the place where i live) have been told to adjust the rubber boot feet. Has anyone else had this problem. Also have a squeeky roof which seems to disappear when I open and reclose the roof catches !!! Is this just the joys of owning a 206 CC. Also need an allen key in case roof malfunctions - does anyone know what size ! Other than that I love it .....
tanyam
Post by tanyam »
hi,
i have the same rattle from the boot. let me know if you are able to locate it.
1 suggestion- the boot catch- sometimes can be loose. Just screw it tight. --- Mine still rattles.
welcome to forum
Tanyam
netball0
Post by netball0 »
hi i used to have a rattle in boot found out it was the jack/wheel brace use bunjy cords to fasten down items and rattles disappeared
We had the same problem as netball0. Jack is contained within polystyrene case in the boot and if not placed within it perfectly the wheel chocks tend to rattle. Pack them with something to stop it.
The allen key is normally in the polystyrene case. The allen key is 4mm A/F from memory, and about 170mm long on one end, and 50mm long on the other.
