Roof help please
boundary
Post by boundary »
Stupidly took the key out of the ignition when roof was partially going up.
Now no life in boot electric. Have the roof in the boot, and the boot lid is partially up, just maybe 4 or 5 inches from close position..
I have just been looking in the boot and found the place for the allen key but not sure if should be turning that? I have no beeping or any sign of power in the roof buttom.
Can anyone help please
Thanks so much
boundary
Post by boundary »
Managed to get the boot lid back down, and have got power back (beeping).
The boot lid is not locked down tho, I can lift it a couple of inches by pulling up.
I assume I need to get this to lock into place before the roof is going to operate again but don't know how.
Help anyone?
Really don't want to have to resort to taking to peugeot as sure will be ripped off big time...
boundary
Post by boundary »
Thanks I had found this and tried, got the roof back down ok with the first steps, but not sure what was meant by close the catches step.
ritchs00
Post by ritchs00 »
Decided not to risk messing it in case made worse, so went and got it reset at local peugeot this morning. £50 :-( but at least it's ok now.
I couldn't get the video picture to come up re how to do manual lift on the roof. Will have to try work this out so I am not in such a pickle if I have any more problems with roof electric. I gather it's a little tricky until you know how
Melanie333
Post by Melanie333 »
My roof wont go down...the screen is across but its beeping as tho its not??? any ideas please will be greatly appreciated ( I did have a new part on the boot lock last year and tested the roof and it did work then but not tried it since )
cass x
Post by cass x »
Hi.. my roof goes down fine and registers that its down properly, but wen i put it bk up it seems to shut properly but is not registering..(it doesn't do the beep after closing) and now it is constant beeping telling me its not up correctly which is driving me mental!! Help anyone?? :D
Both sound like problems with microswitches or faulty connections to them.
