need some help really quick
leicester_lad1
Post by leicester_lad1 »
any info welcome, my missus has just brought a 206cc on a 51 plate. the bad thing is the roof won't work at all. even the windows dont go down first like they should(but work fine off there own switch), theres no beep when u unclip the roof catches but have checked the switches with a multi meter and there ok. also checked the 3 boot switches and the 1 for the pull out cover and there ok. theres 3 other switches on a mechanism which 1 of them doesn't switch across so i have tried to bypass but doesn't seem to make a difference either way. all you get is a beep when you try to operate. there is an ecu/module behind the cover in the boot, is this to control the roof? also 2 relays next to the hydrolic pump which seem to be ok. can you put a supply to the 2 pin plug on the pump to bypass everything? checked fuses under steering wheel, all ok. really stuck and need to gain some browny points with her
p.s the speedo doesn't work but carn't imagine that to cause this fault.
yea i no what your thinking, she's brought a right nail. you wanna try talking her out of something, lol
Besides Robins & Day there's a Pug Indy in Oadby. Might be worth talking to them if you're really stuck.
You're already talking beyond my own knowledge.
Good luck. Feed back any results please.
Welcome to the forum.
