I have seen this problem already posted last year but was wondering if anyone had a possible solution?
Ido all the procedures to put the roof down I.E. curtain closed, latches off etc.
when i press the roof down button the windows come down and everything sounds ok
then the roof stops half way and bleeps. its like the car is telling you that you have let go of the switch (which i have not!)
i try releasing the switch and pressing it again then the roof goes down but at the very end of the procedure
the electrics/hydrolics cut out and the roof just falls into place, releasing the switch and retrying will then close the boot.
Many thanks for any help
