I was just wondering how easy it is to fit a new passenger side wing mirror and also any steps/tips to do this.
thanks in advance
Rob
Fitting a new N/S wing mirror
Globetrotter
Depends on whether they are manual or electric, on a CC I would assume electric? Should be a case of just removing the plastic cover on the inside of the door, removing the three screws holding the wing mirror on and disconnecting all the cables etc. Then do the reverse to fit the replacement.
Make sure you buy the correct one as they are different for the 206/206cc, some aftermarket ones have been known to have incorrect thread pitches on the screw holes as well so you may need to change the screws.
2006 Peugeot 206cc 1.6HDi - "Lucy"
