I want to fit a Parrot 3100 hands-free into my girlfriend's 206CC & I have a couple of questions.
The car currently has a Clarion tuner/single CD player (no other markings on the front - although it has controls for a multi disc unit, none is fitted). How do I get this out? It has four deep recesses (one in each corner) - is there a special tool to get into these, or are there bolts at the bottom of each?
The car came without original documentation, so I don't have the code for the stereo. I have done a search and seen that the code can be obtained at a cost - is there any way of getting the code from the unit before disconnecting it - or some way to avoid having the stereo 're-set' during the fit, so the code is not needed on rebuild?
I have fitted one of these units to my car (an Audi). When I get the Clarion unit out, is it going to be connected by standard ISO connectors? If so, the wiring takes a couple of minutes, if not, is there a conversion kit to ISO connectors available?
I intend to locate the microphone at the top of the driver's windscreen pillar - does the trim just pull off? Any likely issues with routing the mic cable behind the dash?
Awful lot of questions, I'm afraid - any help gratefully received!
Cheers,
Mike
