Does anybody know what the coolant capacity is for a 2 litre 206 coupe cabriolet?
It doesn't seem to state it anywhere in the literature I have.
thanx
206cc Coolant capacity
There is no real need to ask the same question twice slayer, if someone has the answer I'm sure they'll reply.
I've searched the forum, and my handbook and can't find it anywhere.
I suggest you ring either your local Peugeot main dealer or indy who should be able to tell you, alternatively a local motor factor who sells antifreeze should be able to look it up for you.
Make sure you get the correct anti-freeze - there are different kinds and you shouldn't mix them. Myself, for the cost involved, which will be modest... I'd head for my Peugeot main dealer parts department.
Perhaps when you do find out you'll feed back on here please for the benefit of others.
Many thanks,
Regards,
Many thanks,
Regards,
