Engine management light
longyledge
Post by longyledge »
Hi I have a peugeot 206(not CC) and have a problem - the engine management light came on a couple months back when the car began to tick over irregularly, so i took it to a garage(not a peugeot main dealer) and they could not diagnose the problem properly so simply cleaned the valves including idle valve and reset the light. The problem seemed to subside however the problem has again reared its head and the car is again struggling when it ticks over with an irregular chugging and the engine management light has come back on. has anyone got any ideas what it could be?
kinny777
Post by kinny777 »
could be coil pack or stepper motor you need a garage with a diagnostic machine and they will give you a fault code and fault. sounds like your other garage didn't have a machine that could read your car.
