Roof sequence
jmathergb
Post by jmathergb »
windows would not open prior to opening sequence but roof continued to open as normal. Ater opening not finish sound to indicate end of sequence. Same on closing and windows would not operate when roof down.
Checked the three micro switches which where all opening and closing as usual.
Fault was two brocken wires under the grey cover and next to hydraulic pump on Pax side rear boot. The wiring would seem to have been put on too tight fixed to the underside of the boot lid.
Soldered both back together and left fastening loose for slack on future operations. Cost working with local car electrician £55 instead of Peugeot open ended contract for checking and finding out the robbery price of micro switches and ecu which where £75/micro sw(could have been any of three or ecu around £175 all of which where OK.
Hope this helps future 206cc owners.
John
jmathergb
Post by jmathergb »
PS to roof sequence. Original fault had constant bleep sound when driving but stopped when car stopped.
John
Well done John and welcome to the forum. Your experience will no doubt be of benefit to others.
