car cutting out
chriss-CC
Post by chriss-CC »
Pleaseeeeee can some one enlighten me. I have a 206cc 02 plate. In the last 2 weeks i have changed the battery and had the car serviced. For the first time 2 nights ago i was driving when the battery sign lighted up on the display, then the abs and brake fault sign, and the trip computer said BATTERY CHARGE FAULT. then braking fault then abs fault. I left it a lone then the next day the same thing happened. This time after a few minutes of flashing the car functions froze. The idle stop moving, the car would not accerlarate, the doors locked by themselves. Turned the engine off, and it would not turn on till 20mins after. Next day the engine wouldnt turn on at all.
HELP PLEASE
reap
Post by reap »
your car battery dead,dying or alternator not charging or common fault is the battery earth lead has broken off the top of the gearbox.
go get it checked.
chriss-CC
Post by chriss-CC »
shouldnt be the battery since got it brand new under 2 weeks ago. that leaves two other options, thank you very much, i will get that checked out, and let you all no the outcome.
Why did you change the battery?
chriss-CC
Post by chriss-CC »
well i went away on holiday, for a week, a family member tried to start engine mid week but it was already dead. when i came back i jump started and it worked but by next day it was dead. Got the battery charged but no luck.
reap
Post by reap »
got a current drain.something on all the time in ,on the car? aftermarket stereo? :)
