Car shakes On Start Up :(
raks111
Post by raks111 »
Hi just wondering if anyone else has this problem. When i start my car up in the morning it tends to shake a bit as if the revs not enough. If I put my foot on there accelerate its ok then when I let go the whole car starts to shake again. If I start to drive down the road its ok after 2min and it doesn’t come back till say if I left it all day and then started it up again in the evening??
Any ideas
reap
Post by reap »
sounds like hydraulic followers if its a 2.0? :)
I wonder how often the oil and oil filter have been changed.
Peugeot say every 20,000 miles or 2 years whichever comes sooner but I reckon this probably allows sludge to build up and exacerbate the cam follower problem. Surely an oil and filter change every 10,000 miles or annually would be preferable.
As a matter of interest, what's the history on yours raks111 ?
raks111
Post by raks111 »
i have changed mine every year lol :P i get Mobil from halfors and do it. might take a shot hydraulic followers i think :S
reap does know his stuff !
raks111
Post by raks111 »
reap wrote:sounds like hydraulic followers if its a 2.0? :)
how much does it cost and i dont even know where that is so if you could give me some info please
reap
Post by reap »
they cost from a dealer about £800,900 pound fitted.
you have to strip alot of the top of the engine off and cambelt off and cams out.quite involved. :)
id do them if you were local for £400,if that helps. :)
faur
Post by faur »
yesterday ive got my 206cc 2.0 after lifters replacement and now theymake tik noise the garage said it will pass away is it natural that lifters make noise when they just new and will it pass away after some use
AlexMc
Post by AlexMc »
My wife's 2.0 has had the lumpy tick-over from cold / cat fault / pollution fault for the last 2 years. Working in motorsport, I've looked into it a bit on and off. Last week it happened when we were both on holiday and I had a chance to look at it.
First job was to take the coil and spark plugs out. The tops of 2 plugs were wet with oil but the tips were the right colour. After cleaning the plugs and hosing the plug tubes down with WD40 I re-assembled and gave it a go. Ran the best it has in years!
I suspect the way the cylinder head and cam carriers are assembled can cause a small oil leak onto the plugs which from cold causes a missfire.
Any garage that changes the hydraulic tappets / coil / other expensive part, to fix this problem would normally take the plugs out and give them a wipe over which will mask the problem making you think you've paid for a genuine fix until it goes wrong again.
My advice is clean your plugs every 6 months and you'll be laughing as you spend your tappet money on a nice summer holiday!
Alex
