Remote Locking Not Working
Tremor
Post by Tremor »
Hi all. This is my first post here.
I have an 2002 cc, which I've had from new. Just recently, the remote central locking has stopped working. I'm pretty sure it's not the key as the spare doesn't work either.
I'm wondering if it might be a fuse, but I'm having problems working out which fuse it might be. Anybody here know what the fusebox layout is?
I think fuse 16 controls the door locking/ unlocking. Look in your manual around page 105 for the layout.
Perhaps the remote control just wants reprogramming. Normally required after the remote control battery has been changed. (I assume you have tried renewing the batteries in your remote controls.)
1. Switch off the ignition.
2. Switch the ignition on again.
3. Press button A (the large one) on your remote control.
4. Switch off the ignition and remove the remote control key from the ignition lock. The remote control should now be working again.
This is all explained in your owners handbook - somewhere around page 69 I think.
Good luck,
Welcome to the forum by the way.
