207cc - does 206cc wind-break and pugmatic unit fit?
slimgym
Post by slimgym »
I see the 207cc uses a different, folding, windbreak (£165:yikes:), just wondered if the 206cc windbreak will fit. I personally doubt it, but I'm sure someone else has had a go ;)
Also (again unlikely) whether the pugmatic/conmatic units which allow the roof to be dropped while doing up to 40km/h and movement one-touch, if anyone has tried these on the 207cc.
Dave
I understand that the 206cc windbreak does NOT fit the 207cc.
slimgym
Post by slimgym »
TVM for that, I thought it probably unlikely given the 207cc is wider and longer but worth asking all the same. Also the 207cc version folds in half to fit front to back in the boot when not in use.
Dave
reap
Post by reap »
the pugmatic wont work neither(yet) new 207 electronic system is can can system. and the old 206 has van can systems. :)
slimgym
Post by slimgym »
Many thanks both, I suspected the same but good to hear it is so. Or isn't so, as it happens :)
Dave
