airbags
tyrefitter
Hi everybody just bought a cc thats had a slight bump on the front o/s and it seems like the pretensioners may have gone off the airbags are all intact but both seatbelts had locked up although the drivers side has now freed itself do I have have to replace both belts and the module or can I just replace one and not the module or can I use a second hand one I do have access to a full set from another car but I'm not sure if they will be compatible or not any help will be gratefully received as I am being told lots of different things from other people that you have to replace everything and have it all reset at Peugeot dealers only at extortionate money hope someone out there can help regards Brian
reap
you will need to change the pretensioners(both) and ecu.
second hand pretensioners will pop right in(as long as they havnt been fired?)
and a second ecu will work as long as its from same age vehicle and same spec ie passenger airbag and disarming switch etc.
a new ecu would be better but would need to be electronically unlocked and configured to the car(pug only im afraid.
