does anyone know how to remove the arched instrument cover above my clocks as i need to get at a wire behind the speedo, i'm having a real nightmare with this,
thanks,
yorobbo
instrument cover removal
Dabz
remove the two screws from the lower steering wheel cover and pull that off. The top steering wheel cover should then be able to be removed.
To the right hand side of the bottom of the instrument cover will be a metal clip - pull it towards you (often very hard) and it'll clip off. you should then be able to pull the arched cover towards you and it'll clip out
the rest removes by screws which are easily visible
hope this helps, I reserve the right to have forgotten a stage
