ABS Reluctor ring or Magnetic
Hi, so this weekend i decided to check out why my ABS light is on and ESP is not working, (only had the car three weeks.) After a global check on Planet i found my left front ABS is faulty. I took the wheel off expecting to either replace the sensor or clean the ring, but the ring is not there!. Is the ring on a 2004 53 plate a reluctor ring or magnetic? They are easily available off Ebay but i'm not sure which one i need. Does anyone know? Cheers
2002 02 plate 206 cc (Bought for my Niece:) (Sold)
407 SW
2004 206 cc 2l se (joint toy)
Vincent Rapide (My toy!!)
I have PP2000 and can help others locally:)
407 SW
Re: ABS Reluctor ring or Magnetic
At that year should be reluctor on the front, magnetic ring on rear.
Thank You!
407 SW
407 SW
