Center Console LCD Failing
Earthman
Post by Earthman »
Hi ! Just bought a 206CC with broken center console LCD (some segments of the LCD no longer light up). Is this something fixable by changing some parts or do I need to replace the whole unit ? How much would it cost ? Mine is a 2001 2L with no mpg reading.
Thanks.
Sickboy
Post by Sickboy »
Iv'e got the same problem,I found this info from REAP in another thread so I guess this is how to correct the problem.
the plastic couling round the clock pushes away from you towards windscreen and at the same time pull it up.it will pop of very easy.
then undo x2 t20 torx screws that hold clock display to the dash.
identify which bulb isnt working in the back of the clock
turn the bulb holder through 90degrees
change bulb,check,rebuild
very easy.5 min job.
hope this helps
