Most often problems..
stam_par75
Post by stam_par75 »
I ve just owned a 206cc and i would appreciated a lot, if you could help me with the following issues.
1st) it looks that one of the most often failures for this particular car is the co-driver airbag failure. Is there something i can do about it or is a oneway solution to visit an authorized service provider? If i deactivated it and then activate it again the problem seems to dissapear.
2nd) i cant manage to have enough heat . i turn on the a/c put it in the maximum or something less (27 ,26 or whatever) and i dont get any heat. It seems just to warm the air, but not enough, to provide heat. Im doing something wrong? I ve tried to be warmed without turning on the a/c and guees what! The same thing! Only a bit of warmness...
3rd The most famous of all (in my opinion), noise! Annoying noise from the left of the driver seat (i think from some point of the upper driver window side)
Any help would be appreciated..
Lyndon
Site Admin
Post by Lyndon »
1st) never heard a air bag failure before :?
2nd) is the CC second hand, then maybe it needs the a/c repressurising or topping up.
3rd) sounds like the window isn't seating correctly, maybe needs the door realigning BUT this as been known to induce water leakage :shock:
