Brembo's for the CC..... Help
SILNER
Post by SILNER »
After some information if any one can help :? Im after a set of Brembo four pots for my 206 cc and was wondering if anyone already has / or knows if the ones from the 406 coupe would fit as in same mounting brackets etc... :?:
marcelnl
Post by marcelnl »
the 1.6 has two different braketypes, and I think the same goes for the 2.0.....so perhaps a bit more could help the people that might know in giving you an answer.
Would Brembo not have that info at hand BTW ?
black 206 CC 2.0 (2001)
407 SX 2.0HDIf (2004)
SILNER
Post by SILNER »
:D Just to keep you informed the 406 Brembo calipers fit directly onto the 206 just needs to be spaced 3mm to keep disc central ( using 307 discs ) and a 8 mm spacer so the caliper clears the wheel ( by 2 mm ) A cheap 4 pot conversion. 8) And there are only one set of Brembo's on the 406 so no choices just gotta find them i you want the conversion.
Chadd
Post by Chadd »
Or you could do what Ive done and get them made by brembo.
Darran
member 365 and 176 according to owner list....SPOOKY!!
My new new website!! check it out and dont forget to sign my guestbook with your comments.
[url=http://www.freewebs.com/daz206cc/]Project 206cc[/url]
Lyndon
Site Admin
Post by Lyndon »
on side note, your CC finished yet chadd :?
