Which kind of petrol....?
nykS5
teddy206 GTi
I've used Optimax and BP Ultimate in my GTi and when i first got the car i couldn't tell the difference between the fuels but with the Optimax it definately run smoother. It's more noticable driving round town than when you have foot to the floor.
Only used Ultimate once so can't tell the difference between it and Optimax. Normal UL seems a bit lumpy.
carl
I used to get at least 10% better fuel economy in the Impreza when using Optimax. I've tried it in the CC but it doesn't seem to make any difference, nor any difference to power/smoothness, so it doesn't justify the extra cost. I don't put anything except Optimax in the TVR. I think it's mapped to run on normal UL, but it doesn't seem worth the risk for the amount of mileage I do.
britboy
It's more oxygenated therefore can give between 2% and 12% more performance then the normal stuff.
Just use the normal stuff for your car.
Impreza has a computer which can tell which type of petrol you've put in there and change the engine management system accordingly.
Pergeot it will make no noticable difference though. Apart from in your wallet.
teddy206 GTi
Derek
i have tried optimax twice, for approx 1500 milers each time and i noticed a massive difference - normally 5/6p per litre
mpg increases by approx 1mpg maximum and performance difference is minimal so save your cash and just stick to the cheap stuff
Derek
Darth Bourj
The higher octane of optimax and super unleaded petrol will result in less carbon deposits building up in the engine. So the effects of using it may not be immediately apparent. I have been lead to believe that it will increase the life of the catalyst and maintain good engine performance/ economy. That said it probably isn’t worth the extra cash. Although I always use it.
It is probably more noticeable in performance engines like that of an imprezza. I believe the engine timing decreases slightly due to the cleaner explosive nature of such fuels. Non Injected/ ECU cars will not notice real improvement unless the timing is changed. As I understood it-Any fuel-injected car will automatically adjust it-self. I can’t think of any new cars that still use carbs.
I had a similar discussion with my old chap a couple of months ago. He thought it was unnecessary buying super unleaded etc. He owns a 6-month-old Picasso with the same 138bhp engine as the cc. He had always purchased his petrol from ASDA and Tescos. Last week his multiplexed Picasso came up with an engine fault.
When he took it to the dealer they said it was due to poor/ dirty petrol. So say the cars engine management system is so strict concerning air pollution that it sensed an issue. The petrol was drained and injectors were cleaned and touch wood his car has been ok ever since. He was advised to use branded petrol such as BP or Shell. Although I was under the impression that one of the supermarkets used the same petrol. Anyway he isn’t using supermarket petrol anymore.
teddy206 GTi
carl
Interestingly I noticed today that the filler cap on the TVR says "Use 98 octane super unleaded only".
Anyway, I'd certainly agree with the advice to steer clear of supermarket fuels in any car -- stick to Shell, BP, Esso and Texaco.
andrew
Isnt tesco texaco? It used to have a texaco logo on the one near us, dunno if its still there. Im going to continue to use supermarket fuel! and continue to replace cars every 3 years, so i do not see what difference its gonna make.Interestingly I noticed today that the filler cap on the TVR says "Use 98 octane super unleaded only".
-- Andrew
[url=http://www.peugeot206cc.co.uk/newowners?id=429]Ex-Owner 429, now 307cc180[/url]
