Putting the roof down
Greenday
Post by Greenday »
Is there anything built in to stop the roof from being put up or down while the car is moving, i'm too scared to try it so i don't know if works or not?
For 206CC automatic roof devices check out
www.pugmatic.co.uk
Burge
Post by Burge »
Greenday,
The roof will not operate at speeds over 7mph. Under that and you can do the roof on the move. If you are doing the roof and on the move the roof will automatically stop when you go above 7mph and restart when your speed drops again. I know cos I do this regularly when driving into the stable yard to save time. You will get a bleep if you try it too fast. Found this out when my dad thought he was operating the window button at speed on the motorway and when the CC bleeped looked down to see him trying to operate the roof in error!!
Burge
[img]http://store5.yimg.com/I/kalinc_1702_4409155[/img]
Greenday
Post by Greenday »
Cheers, hadn't been brave enough to try but that's good to know just in case i need to move and the roof isn't quite down
www.pugmatic.co.uk
