More of a mystery than a problem.
I have just replaced my battery with the Bosch recommended S4 52AH. I noticed that it is shorter than the old one (Also Bosch). Further investigation has revealed that my old battery was for 2 litre cars and my new one for 1.6 litre. I have a 1.6 litre car. The old battery fitted perfectly in the box - the new one has a large gap at one end.
Question 1. Should the gap be at the back in order for the cooling air to circulate more freely, or the front to avoid shifting on severe braking (impact)?
Question 2. Are there two sizes of boxes, and did the 1.6 automatic have the larger for some reason?
Battery box
- rhume
Re: Battery box
I'd put it at the back of the box and put some packing in to stop it moving. All battery boxes would be made to the largest size probably to save cost.
Re: Battery box
Also depends who recommended it .. some have a habit of recommending the wrong one .. the CC batteries are taller than the hatchback as well ..
Luditus
Re: Battery box
Thanks for the replies. At the moment the battery is about equidistant from each end, whilst a suitable block of wood is being furnished to place at the front end. I sourced both the old and new battery from Euro Car Parts, so unless their website has changed in the last 6 years (quite likely), I assumed I would get an identical replacement. The automatic has its ECU bolted onto the back of the box leaving little room for the brake reservoir behind it. A shorter box would have made the reservoir more accessible, which lead me to think that the automatic ought to have the longer battery. Any way, I'm happy to use what I've got.
Re: Battery box
If the battery is not secure, it's an MOT failure.
Luditus
Re: Battery box
The only security that I see is the diagonal strap over the top. There is no register for the strap on the battery, so without any packing pieces there is only stiction preventing fore and aft movement.
Re: Battery box
That works ok until you get delivered the lower height battery by Halfords or the like!
Luditus
Re: Battery box
Even more packing then? What a bodge!
Re: Battery box
I have a 1.6 automatic. There doesn't seem to be a battery box as such; the battery rests on a plate and appears to be clamped down by using the flanges on the sides. It's a big battery, and fits on the plate with no room to spare.
Luditus
Re: Battery box
Yet another variant then? Since my first posting, I've been on a number of battery websites, and on a few (where they are facilitated), I have found that if I input my vehicle type, the result is the battery that I now have. If, however, I input my vehicle reg., then my old (longer) battery comes up. Unfortunately the Euro car parts site made no such differentiation. So, in a nut shell, I have the wrong battery due to duff software - I reckon.
