Rear Bulb Function
Rubyoptics
Rear Bulb Function
Post by Rubyoptics »
Hi all, quick question if i may. I just changed my rear lights to something a bit more modern looking and i'm blown away by the appearance (i'll get some photos later if the weather stays nice). I have a small problem though...during a quick function test, all the bulbs bar one are working. The rear lights themselves (activated with the headlights) work fine, brake lights work fine, both indicators work fine, when i shift into reverse though, only the right hand side bulb lights up. The bulb in this position on the left of the car seems to serve no purpose whatsoever. On the standard '03 rear lights, should both side illuminate when reversing as for the life of me i can't remember! Many thanks as always!
Re: Rear Bulb Function
Yes, both reverse lights work on standard rear light units.
In the UK you quite often get fog light on the right, and reverse on the left which is the min legal requirement. If you have aftermarket lights, this may be the case, only they would be the other way round on LHD cars (e.g. Fog on left, reverse on right.
Rubyoptics
Thanks for replying as usual Col. Seems i jumped the gun on this one though. After writing the post i realised that in my excitement over the new lights I hadn't checked the actual bulb to see if it was good or not. Lo and behold, duff bulb! By strange co-incidence I also lost my front right headlight (of course it would have to be the bloody right hand one!) so am now trawling through here checking what bulb i need for that!
H7 if the crystal dual-bulb. H4 if single bulbs.
Rubyoptics
Thanks Gazza. I found the extremely helpful bulb listing post on 206info which listed all the bulbs used. I don't suppose anyone has any experience of the Philips range of ultra-white or extreme range of bulbs? Are they worth the extra outlay?
I think I used the Philips Extreme in my daughter's 206CC .. I tend to go with theirs as they tend to last longer. Get mine normally through powerbulbs ..
