Hi All
2004 1.6i Allure, TU5JP4 NFU
Having a bit of engine misfire, tried a couple of things but now looking to change injectors.
Had a quick look, 2 x 10mm fixings holding down the rail, bending a ring spanner to fit today, but wasn't sure if there is enough room above the rail for the injectors to be removed without taking off the entire intake assembly?
Can it be done?
Removing injectors 1.6i
Re: Removing injectors 1.6i
Injectors aren't very long, about 3 1/2" . It's been a long time, but don't recall many issues in removing them.
