I am after a complete set of the roof system
I want to mount on a board, to help fault find roof issues
I want to create a wiring diagram with each step as it happens to post on this site
If you are breaking a 206 cc and can take out (or I will come and do it) I would be interested
Reason I want to do this is I have just been charged 480 for a so called Peugeot main dealer roof specialist to fix (5 hours labour at 80 + vat) he even had a printout telling him which switch was faulty (unbelievable)
Roof ecu, with loom, switches and hydraulics
ianthelaugh
Artermis
Re: Roof ecu, with loom, switches and hydraulics
I've no direct experience but I believe the Peugeot Planet software (often referred to as "Planet") has the diagnostic capabilities, as you suggest, to point you in the direction of the switch which is giving you the grief.
Wiring diagrams are largely available via this website. I believe they're also available via service box for a fee too.
It's a bit of a way from you but Roger Windley (salvage / breakers yard), in Tattershall, Lincolnshire, are breaking a bunch of 206cc at the minute if you wanted parts.
Ben. 2006 1.6 HDi Allure
ianthelaugh
Thanks for the update, I will give them a call
