06 206 sw oil pressure gauge shoeing gauge fault
Terry72
Post by Terry72 »
06 Peugeot 206 sw oil level gauge flashing oil warning and stop light on?
He I bought a 2006 Peugeot 206 sw 2 weeks ago on sunday I noticed the oil pressure gauge on the dash was displaying an oil level gauge fault ie: ------ six underscores flashing with no 'min' lit up. At the same time approx 5 secs after starting the engine the oil warning light comes on the car bleeps and the stop word illuminates and flashes.
Yesterday I changed the oil pressure switch(located on the oil filter base) but this hasn't fixed or changed the fault.
When checked with the dipstick the oil is at the top level and quite clean .... apparantly the car was serviced 3 weeks ago.
I'd really appreciate any info on what this could be and what I should try next :( only a week and a half old (to me) and I can't afford another.
Thanks in advance
Re: 06 206 sw oil pressure gauge shoeing gauge fault
You need to replace oil level sender. It's the one with the green plug top
Terry72
Post by Terry72 »
Thanks bud. Where abouts is it on the engine?
Which engine?
1.4 and 1.6 petrol - front side of the cylinder block adjacent to the oil filter housing
2.0 petrol - rear side of the cylinder block at the sump to block joint
1.4 diesel - rear side of the cylinder block, between cylinders 2 and 3
2.0 diesel - rear side of the cylinder block, adjacent to the transmission housing.
