My 1999 206 1.6L
Car has been fine, and all of a sudden
Rear Fog light indicator has come on the dash
car starts fine and idles perfect, press brake pedal and rpm fluctuates drops and eventually stalls, also putting headlights on and rpm drops and stalls.
here is a video of my problem on youtube, cant seem to add link on here, please search peugeot 206 1.6 1999 and its at top of page.
Any ideas guys where to start
Just found this broken thing ontop of engine,could someone tell me what it does and could it be related to my above problem
what could cause this.
thank you
Car idles perfect until brake pedal pressed and stalls
mgzt190
Re: Car Stalls when i put headlights on
Lights and ignition are both powered by the engine compartment fusebox. There could be a partial short within it - perhaps due to water ingress.
Slo
Re: Car idles perfect until brake pedal pressed and stalls
Check your earth leads on each end particularly the gearbox to body one, the pic is of the ignition suppressor, stops whining interference on radio or other electrical equipment.
iooiuk
Check battery with a multimeter to see what volts you get with:
A. engine turned off.
B. engine running, but no electrics on.
C. engine running, but lights heater etc running.
Just to rule out, battery or alternator.
