206 front strut replacement
spurds
Hi I am trying to fit a new stuff on my 206 but can not get it in do I have to remove anything ? Like the drive shaft
Re: 206 front strut replacement
Unless for some reason you want to remove the whole strut, you only have to undo the pinch bolt at the bottom of the shock absorber part, the drop link & brake hose clamp and the bolts at the top of turret. Then it will come out. If you want to remove it completely you will need to undo driveshaft and track rod end and the pinchbolt at the bottom of the strut.
spurds
Do I have to remove the hub ? On another site it seems you only have. To remove the bottom track control ball joint and not the hub
As I said, it depends on whether you want to remove the entire strut or just the shock & spring. You haven't said which.
spurds
I am fitting a new strut and spring have assembled it and got the top located but cannot get the bottom in , have been told to remove just the power arm ball joint and that will let me push the hub down
spurds
It need about 2 inches more
Jack up both sides so both front wheels are off the ground, then lever the lower arm down with a long crowbar or similar. I do it like that all the time.
spurds
Many thanks you have been most helpful
spurds
It's a cc 206 guess that's just the same ?
This is the 206CC forum so yes. All 206s are the same. Try leaving both top nuts loose so the strut moves too. Just use them to stop it dropping out. Tighten them once the clamp has been refitted.
Splitting the lower ball joint can be a pain so you want to try and avoid that ... You'll find out when you need to change a lower arm ... Btw the CC uses the GTi lower arm with stronger mounting bushes.
spurds
Gonna get out there and give it a go not having the cc on the road is a bad feeling
spurds
Job done many thanks for all the advice .I had to drop the lower joint that allowed the strut to be refitted . Bring on the sun
