.. Turned off ! (This was done by mistake)
Ok I've think everything still works as such.. I just can't get into the boot / manually pull roof up.
Using the roof button results in beeping.
So roof is left in open position (now collapsed - so I can manually lock) but still I can't close the roof.
I do not appear able to open the boot cover nor the boot itself.. very stuck (& it is Sunday!)
Any suggestions.. As I haven't seen anything which can directly help me to gain access
04 plate roof didn't completely open before ignition was..
JustJ
Karrot
Re: 04 plate roof didn't completely open before ignition was
http://www.peugeot206cc.co.uk/viewtopic ... 73#p120111
Check that post, it may help. The system gets is knickers well and truly twisted if the cycle is completed manually as the final locks dont engage.
I may be wrong, but its worth checking.
K
K
You need to reset the roof so that it knows where it is.
See reap's posts in this thread:
http://www.peugeot206cc.co.uk/viewtopic.php?f=5&t=9896
