oil filter
pugpeg
Re: oil filter
You undo the plastic casing using the nut shape on the end. Element is a paper filter that fits into casing. Screw it back on.
pugpeg
Re: oil filter
just tryed with mole grips very tight mind you so was the sump nut some one likes there spanners lol
Peugeot 206 LX 03 reg 1.4 cc 83000 miles.
pugpeg
Re: oil filter
thats a first had to use a breaker bar exertion and socket never seen a filter so tight.
Re: oil filter
The filter cover/cap should only be torqued up to 18 lbf ft (25 Nm). Someone must have been a bit brutal.
The sump plug should be 22 lbf ft (30 Nm) according to Haynes.
pugpeg
Luditus
Re: oil filter
I think that there is a rubber seal between the housing and block which suffers over time and (guesssing) a quick remedy would be to add more torque. Mine leaked a bit and the garage said that they had to order the seal separately as it is not included with a new filter. Plausible?
Re: oil filter
More likely they didn't change the seal and it leaked. I've always got a new seal with the filter.
