Wing removal
Bootyx67
Wing removal
I have a 2002 plate, does anyone know if the wings are bolted on or welded? Have recently been hit in drivers wing and can buy a replacement relatively cheaply but would like to know if the swap over is going to be the costly part or not??
Enright
Re: Wing removal
They're bolted, but there's a line of adhesive that runs along the top, so they need to be removed carefully.
No special tools needed though, so no extra costs there.
BCingU,
Neil.
Neil.
Re: Wing removal
Make sure it's the right version of wing ... there are two types: Sport which has a wider arch and different front edge and standard. Think most CCs use Sport wings unless it's already been bodged and has standard wings which are much cheaper.Bootyx67 wrote:I have a 2002 plate, does anyone know if the wings are bolted on or welded? Have recently been hit in drivers wing and can buy a replacement relatively cheaply but would like to know if the swap over is going to be the costly part or not??
Re: Wing removal
That's assuming it's the front wing, as Booty hasn't said.
Rear wing is welded.
Bootyx67
Re: Wing removal
Thank you people! It's the drivers front wing.
Bootyx67
Re: Wing removal
Gazza, as far as I know it's the original wing on the car.....how would I know the difference between the sport or standard wing? Is there a tell tale sign to look out for do you know?
Re: Wing removal
If you compare pics of a CC or GTi with a basic model you'll see the extra flaring over the wheel arch.Try Google images or even ebay.
There was IIRC a thread on here where a CC had been fitted with standard wings and a non-sport front bumper.
We sssumed cheap accident repair.
