Battery Flat
tyealia
Battery Flat
Post by tyealia »
Hi everyone. I left my car for 3 weeks without using it. I am fairly certain I had everything turned off, when I came back the battery was completely flat not even a single light. It is a 6 month old battery and the only new thing in the car is a new aftermarket stereo.
My mechanic drove over and he brought a charger that he connected to the battery and charged it for about 15 minutes turned it on and it was working. I drove around and it has been working though this morning I had to turn the key and listen to a longer then normal starting sound. I only drove it a total of about 1 hour after the jumping charge.
Since it was only 3 weeks after complete discharge of a 6 month battery should i be concerned and go have all the electrics checked to see if there is a parasitic drain.
Also should I take this battery to someone to slow charge it or is it enough to rely on the alternator.
Cheers!
Peugeot 206cc 2005 (2014 newish motor)
1.6L, 4 cylinder , 50 litre
Enright
Re: Battery Flat
Post by Enright »
If I were you I would invest in something like an Optimate charger - you can get them for about £40 new on eBay. They are a charger, but they are also a "battery conditioner" - that is, they will charge a battery from flat in extreme conditions, but ordinarily monitor the charge of the bettery and simply keep it topped-up.
BCingU,
Neil. ;)
Re: Battery Flat
If you have eliminated things like glovebox ot boot light staying on, I would be looking at either the new battery being faulty, or more likely the new stereo or associated wiring.
They have 2 power supplies, one for the memory (permanant supply) and one for powering it (ignition switch controlled)
Either way it shouldn't go flat in 3 weeks
tyealia
Re: Battery Flat
Post by tyealia »
Re:Capn Well the first two are easy I just found out im even supposed to have a bootlight need that replaced hehe. Not sure I have a light in my glovebox either. I am taking it to my stereo guy thursday to inspect if theres any drain. I will write back with progress
Re:Enlight Ill look into it if the audio intalled comes up with no problems
