hi can you help me
ajs
hi can you help me
Post by ajs »
hi all ive got a 53 plate 206 1.4 petrol i cannit get 5 or rev gears the 3 rods are stii on from the gear box to the gear shaft 1-4th gears go in and out ok cheers and thanks if you can help me :thumbs:
Re: hi can you help me
Can you get the lever into the 5th / rev gates or is it as if as if the gates are missing and the lever won't go into those positions, as that will help pin it down?
ajs
Post by ajs »
the gears wont go in no 5th or rev it feels like the gears arnt there i will try to see if i can work the gear gate by hand to see if i can get the gears thanks for getting back to me
