Automatic windows up on closing Roof
c10ttn
Hi, the missus has a 2004 1.6 Allure and it seems strange that when you close the roof the windows don't automatically close after the roof has. Is this normal or is there a possible problem. Thanks
EdmundIJones
Re: Automatic windows up on closing Roof
Normal I think, mind is the same.
yorkielassy
Same here...
Ex 206 CC'er.
That is how it is designed. The windows shouldn't go up until you've secured the front roof clamps. Then they will go up when you operate the window switch. If you haven't secured the clamps then you'll get a warning "bong" to remind you to do so before the windows will operate.
