wanted wiring loom for 206cc 1.6 16v
greengecko
wanted complete wiring for 1.6 with bsi ecu keys and the whole lot please help need it badly
Enright
Re: wanted wiring loom for 206cc 1.6 16v
Be very careful - there are at least 3 different types, and multiple sub-sets.
You ought to register yourself on Peugeot Service Box (as an independent garage) to see what you've got and what other ones will be compatible.
I have a complete loom, but I wouldn't sell it to you unless I knew it was the right one for your car.
(That sounds unhelpful, but it's really protecting you from getting ripped off)
Can you put your location in your profile, and then post the age of your car?
Even better if you can include the build number, which is on the same label as the paint code on the driver's side B-pillar.
I'm just about to go on hols, but if you want to PM me the VIN number from the little window under your left-hand windscreen wiper, and tell me why you need a BSI & keys, I may be able to give you a few pointers.
BCingU,
Neil.
Neil.
greengecko
hi the story is ....
my Peugeot was a 1.4 and the guy who had it had an engine swap from a cabriolet to the hatch
so 1.6 16 v nfu coded engine i messed up the wiring and chop quiet a bit of it off
i have the dash and everything but to re wire the car is a nightmare
so if i can get all everything from bsi ecu keys and all with complete wiring of a 1.6 hatch(xsi)would be great just install and reset.but im having trouble with that as im in Seychelles not UK.
so if you have all the above i would gladly appreciate it a complete compatible set would be great it has to come with the dash display ,digital climate control display, and instrument panel display
i need urgent because ryt now its just a sitting lump in my garage........
and ya id really appreciate some tips so i can put up a good fight with it
you can email me at
jnjautoparts @ hotmail . com
just ignore the spaces
you can email me at
