From pretty much day one I had the anti pollution fault come up on my car. The car would beep, go into limp mode and the engine management light would be on.
A tank of BP ultimate usually did the trick for a few weeks as well.
This has been an on/off occurence which is why I felt like it wasn't serious. Surely if it was a serious fault it would be on all the time? One time it had been on for 3 days and the car was actually revving by itself. Apparently this is because the car is trying to get rid of any dirt in the tank or something. It's like a self-cure. However this was REALLY scary because even when I took my feet off all pedals the car still moved by itself and showed no signs of slowing down like you would expect it to if you weren't on the accelerator pedal.
Anyway, after over a year of this on off stupid problem, my car decided to do it on a REALLY busy 5 exit 60mph road roundabout. The car stopped on the actual roundabout. We couldn't get it to move as the accelerator wasn't responding again. Then after a few start ups it was revving by itself. Rang breakdown people through my insurance and they came and rescued us. Got it taken to the same garage that did my cambelt.
Plugged into a diagnostic machine thing.
Two fault codes came up - P0221 and P0226. The garage called Peugeot directly and the fault codes are so common they could tell them instantly without having to look anywhere what they were.
Both of these codes are related to a faulty throttle position sensor. The garage removed the sensor and replaced it with a new one and then reset the throttle cable. It was THAT simple!
The fault has been gone for nearly 2 weeks now and I am SO happy. All in all it cost £231.88 so it wasn't too bad. At least I can breathe now
